It is currently Sat Jul 19, 2025 8:48 pm
PostPosted: Thu Nov 01, 2007 3:09 am
I got some stuborn stains on my spring steel slats from bending walnut. It
looks like tar. luckily the stains where on the interior of the bent side.
Anyone have a effective method for removing the tar like stains from the
slats? Thanks for your help.
PostPosted: Thu Nov 01, 2007 3:53 am
I think that any thinners tough enough to remove the stain will also remove the bluing. Mechanical removal will definitely damage the bluing.
I use spring steel slats & the bluing wore off very quickly. To keep the oxydized metal away from the sides, I wrap the sides in Alum foil. This should also keep the resins off your slats.
By the way... When bending Koa, I wrap the side in parchment paper first because aluminum can turn Koa green. I still use aluminum foil to prevent the slats from staining the wood through the paper.
I don't worry about any stains that collect on the slats.
PostPosted: Thu Nov 01, 2007 5:24 am
Thanks for replying Daniel. I used parchment paper, but It seems as if the
resin penetrated the paper and deposited a fair amount of tar like resin on
the interior side of the wood as i mentioned earlier. Maybe I used too much
water. For the second side, 'll use much less. I used a soft steel wool (000)
to remove resin with a little water. I will try thinner next time. Thanks again.
PostPosted: Thu Nov 01, 2007 6:21 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use Acetone!
Wear gloves and use papertowels or a non-scratch pad made for non-stick cookwear!
Mike Collins
Mike Collins
PostPosted: Thu Nov 01, 2007 6:42 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Try any pitch/gum remover used on saw blades or Renuzit, a non toxic remover used tool clean sanding belts.
Hank Mauel
PostPosted: Thu Nov 01, 2007 7:35 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Naptha or kerosene will work. And some extra fine steel wool and some elbow grease.
PostPosted: Thu Nov 01, 2007 2:15 pm
Thanks everyone for the great tips. Todd, Your craft paper almost looks like
a carbon copy of the wood. My craft paper stuck to the side on the first
bend. I know I used to much water. I just lightly sprayed the craft paper on
the second side. I'm leaving it in the bender overnight. If It comes out ok,
then I think I've found my formula, for walnut at least.
PostPosted: Thu Nov 01, 2007 2:48 pm
Easy-Off for those tough stains...
PostPosted: Thu Nov 01, 2007 3:36 pm
[QUOTE=Rick Turner] Easy-Off for those tough stains...[/QUOTE]
It works great on graffiti too!
PostPosted: Thu Nov 01, 2007 3:46 pm
You have graffiti on your slats?  What kind of wood were you bending?  Musta been Gang Zoot!
PostPosted: Thu Nov 01, 2007 7:47 pm
What can I say, its a tough neighborhood.
PostPosted: Fri Nov 02, 2007 1:10 am
Rick Turner Wrote: Easy-Off for those tough stains...
For some reason I think that would work.
